SwaleSmith
Seems I am in the $hit. was doing some tweaking trying to see if I could get my cpu stable with sensible...ish volts temps etc was runnign 1.400vcore & 1.35 qpi/dram volts as I was priming say 2mins in the pc just shut off thought it just failed prime....so attempt restart and the pc seems to start working my LCD status light go's blue saying its got signal but when it seems like its about to post the ROG logo I get a white quick flicker in the right hand side of the screen and thats it.
The Blue light stays on but nothing, looking at the tweaker/bug lcd everything seems normalruns through post checks and so on and finds no errors.
I have tried all the obviouse like turning it of resetting cmos everything you can imagine, tried swapping GFX cards but its still the same....have I destroyed my CPU or something wasn't running any volts that were too much nothing amber or yellow...or red of course
One more thing I pulled my Heat sink off (heat sink was mounted properly temps were even and good) fired up the pc with no heatsink and the cpu gets hot fast as it should.....would that happen if it were dead...and surely the m/board would do no post checks liek it does when the cpu is removed if it was dead or is it possible that all this could happen.
Is my M/board playing up or is the CPU fried...or is there some other possibilty????
ps. I extremely doubt this is PSU related its about 7 months old with no history of trouble, and have also tried one stick of ram.
sorry for the long post...
Thanks in advance
Thanks in advance
