28-02-07, 11:22 AM
OC3D Elite
Inno3D Introduces The WAVE Passive Cooling Solution
Inno3D has released a passive cooling solution for their mainstream 7 series, known as the WAVE.
Link
__________________
Originally Posted by name='Jim'
"Jonathan 'Fatal1ty' Wendel may be 12-time world gaming champ, but how does he cope inside a 50c hot box sucking on a heavy load?":rocker::rocker:
28-02-07, 11:32 AM
OC3D Elite
Am I wrong in thinking that "Circulating Heat" goes against the basics of cooling.....?
If they made that loop on the end SLIGHTLY bigger and put some fins inside it then gave you the option of a quiet little 40 mm fan they would be onto a winner tbh, could probably sell it as a standalone product.
__________________
Just ate 5 Cadbury's Double Deckers in 30 minutes
28-02-07, 03:52 PM
OC3D Elite
I`m not overly groinily excited about this.
28-02-07, 04:49 PM
OC3D Crew
i dont think this is ideal, h/e its the same concept as ceiling fans it just circulates the heat, to bring it more to the ambient air temp(not quiet near thou)
28-02-07, 05:59 PM
OC3D Elite
Looks kinda gay.
28-02-07, 07:18 PM
OC3D Elite
anyone care to explain what the hell "h/e" means as it bugging me now i keep reading it.
Ta
__________________
28-02-07, 07:19 PM
OC3D Elite
but its pushing the heat along the heatsink to probly where its cooler. is that not a good thing.
__________________
28-02-07, 07:41 PM
Newbie
h/e is however
Dunno if that would actualy work tbh
28-02-07, 08:04 PM
OC3D Elite
Confuzzeled!
I thought we are looking for better cooling, getting rid of heat.. not concealing it..?
01-03-07, 03:32 PM
OC3D Elite
From what I can see of the limited pics, it`s just a shaped heat sink, it won`t push any heat, it`ll just exhorb it and heat up. If u stuck a little fan either under it, i.e. by the base, or even @ 90 deg to the side of it, it will have a push.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
