Go Back   Overclock3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #1
Old 13-02-07, 01:57 PM
IAmATeaf IAmATeaf is offline
Newbie
Thermalright Ultra-120?
What's peoples take on this cooler, read a few reviews and it seems decent enough and very similar perf to the Ninja and TT. Have always been using Thermalright coolers and thought I might get this for my impending C2D upgrade.
  #2
Old 13-02-07, 02:34 PM
FragTek FragTek is offline
OC3D Elite
Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
Anything from Thermalright will be a good solid product. When comparing the top 120mm heatsinks theyre all within a few *c of each other, so just go with what you want really.
I personally love TR products, they're outstanding.
__________________
Asus Sabertooth 990FX | AMD Phenom II X6 1090T | 16gb G.Skill Ripjaws X DDR3 | Thermalright Silver Arrow
2 x Sapphire HD 6870 1gb CrossfireX | LG 10X Blu-Ray Rewriter | PCP&C Silencer 750 Quad | Fractal Design R3 Case
60Gb Patriot Pyro SATA III SSD | 1Tb WD Black | 3 x 2Tb WD Green | 2 x 360Gb Seagate Barracuda
  #3
Old 13-02-07, 02:41 PM
FarFarAway FarFarAway is offline
Newbie
Thermalright are top-notch. I had the XP-120 and it was awesome
  #4
Old 15-02-07, 08:58 AM
Newbie
I assume that when it comes to size it wouldn't have or would have the same clearance issues as the synthe or the tt as they are all based on 120mm fans?
  #5
Old 15-02-07, 11:06 AM
GrimReaper GrimReaper is offline
Member
using the ultra 120 here no issues at all
  #6
Old 04-03-07, 04:58 PM
Newbie
What case do you have? I have a Lian-li 6089B and have sort checked the dimensions and with the Ultra-120 being 160.5mm tall it looks like a very tight fit especially as the case has a windowed side panel. I've just purchased a Gigabyte DS3P mobo and when taking the system apart to fit the new mobo will measure more accurately as I don't want to end up with a cooler where I can't put the side panel back on.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
