Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 23-11-13, 06:41 PM
ahimoth ahimoth is offline
Advanced Member
Sound card and Headphone combinations for multimedia ( Xonar Phoebus, D2X or the STX)
I've read through the forums and I've gathered that two soundcards from Asus are awesome and either one is great. These are the D2X and the STX sound cards. I'm in the market of a new headset and so I thought as I make the jump to a nice high end head set I also purchase a sound card to do it justice. I listen to music, watch movies and play games so features are important.
I was thinking something like:
Razer actually recommends some sound cards to go with their Tiamat, the ones from Asus are Asus Xonar DS PCI 7.1 , Asus Xonar D1 7.1 and Asus Xonar DX PCIe 7.1.Link is here
Other forum members and youtube reviewers have only good things to say about the Audio Technia M50's but these don't have a mic as they're studio headphones so maybe pairing it with a sound card like the ROG Xonar Phoebus is a good idea because it has a mic in the desktop unit.
What do you guys think? I'm open to other headset/sound card combinations.
__________________
i5-3570k @4.5 GHZ 1.336v - Asus Maximus V Formula -Corsair Vengeance 16Gb 1600Mhz Red - Inno 3D GTX 780 - Asus DCII GTX 780 - Asus DCII GTX 780 (not installed) - Corsair 900D - Seagate1TB 7200 RPM- WD 2TB Green - Samsung 530 120GB SSD - Samsung evo 540 250GB (not installed) - Samsung evo 540 250GB (not installed)
Alphacool XT45 480 - XSPC RX 240 (not installed) 140 AF QE white LED - 3 x 120 AF PE - 4 x phobya 120mm - 4 x Bitfinex 120mm pro - 4 x NF-F12 (not installed)
  #2
Old 23-11-13, 06:45 PM
Cru's Avatar
Cru Cru is offline
OC3D Elite
what about a pair of good studio headphones and a modmic?
http://www.modmic.com/
  #3
Old 23-11-13, 07:01 PM
SieB's Avatar
SieB SieB is offline
OC3D Elite
These Zalman mics are supposed to be really good as well.
http://www.amazon.co.uk/Zalman-ZM-MI...I1P7PY2S2E8L3Y
__________________
NZXT Switch 810 - i5 2500K - Gigabyte Z68 UD3H - 8GB 1600mhz Mushkin Blackline - Zotac 970 GE - Crucial MX100 256GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair HX850 - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #4
Old 23-11-13, 07:15 PM
Advanced Member
Thanks guys, these look like pretty good options
__________________
  #5
Old 23-11-13, 07:25 PM
Cru's Avatar
Cru Cru is offline
OC3D Elite
had one of those. seekax said it's crap as he was the one who had to listen to it
  #6
Old 23-11-13, 07:37 PM
AMD Enthusiast
Xonar STX and Beyerdynamic DT770s? Or 990s. 80ohm or 250ohm are great.
  #7
Old 23-11-13, 07:48 PM
SieB's Avatar
OC3D Elite
Scrap that idea then, just saved myself from buying one as well.
__________________
  #8
Old 23-11-13, 08:55 PM
looz's Avatar
looz looz is offline
Advanced Member
Depends a lot on the sound card, though. If you have an integrated circuit you can't really blame the mic.
__________________
i5 4690k - 3*4GB - 2 * Asus GTX 760 DirectCU II - 500Gb 850 EVO - 1TB WD Black - Asus Z97-A
Scythe Mugen 4 - Fractal Design R4 - ZM850-HP - DT-770 - Superlux E205U - Samsung U28D590D - Asus VG248QE
  #9
Old 23-11-13, 09:27 PM
Edge's Avatar
Edge Edge is offline
OC3D Crew
I'm aiming for the STX with Sennheiser HD598s. Might be worth a look. Not surround, but bloody brilliance.
  #10
Old 24-11-13, 06:50 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
Don't get a Tiamat they're crap. Both those and the megaladon's are properly rubbish. :P
__________________
Asus x79 Deluxe | Intel 3930k | 32GB Corsair Vengeance 1866Mhz DDR3 | 2 x 3GB Gigabyte Windforce 780GTX - SLi | Xonar Essence STX | 2 x 256GB Samsung 840 Pros | 2TB Samsung F4 | Corsair RM1000i | Caselabs SM8 - White | 2 x Alphacool 360x60 | Bitspower 400mm Res Top | Dual Laing D5 Pumps | Bitspower C47 Fittings | XSPC Raystorm | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
