Thread Tools Display Modes
  #1
Old 18-11-13, 10:26 PM
jarthur36's Avatar
jarthur36 jarthur36 is offline
Newbie
[WIP]Dragon Blood Shinobi Mod/Build Log [SUGGESTIONS WELCOME]
Intro: Hey, just started up on the forums today although have been watching OC3D for a while now. Primarily, I am 15/16 by the time this will be finished, this means I have extremely limited budget. I am only on £10 a week so getting the money for PC components is difficult as it is. Just to add to the difficulties, my parents are split up so 2 PCs are required(one for each house) but the one I put the effort into is my £750 sweet-spot PC (specs below). Christmas is just around the corner with my birthday just 12 days after so I have plenty of opportunity to make some major improvements to my rig. It performs absolutely fine although slightly loud and its not particularly visually appealing aswell as running a little on the hot side after long gaming sessions.
Upgrade/Mod Budget: <£200
p.s. I have access to any tools I may need.
Specs:
Case: Stock Bitfenix Shinobi Black Windowed
CPU: Intel Core i5 4670k @ 4Ghz
Cooler: Coolermaster Hyper 212 Evo w/ 2X Stock Case Fans
MOBO: MSI Z87-G45 Gaming
GPU: Asus GTX 760 DCUii (I play at 1440x900 so no problems here)
RAM: 8GB Corsair Vengance 1600 Black
PSU: Corsair CX750
Storage: 1TB Seagate Barracuda(7200rpm)
300GB 2.5" 5400rpm(Optional)
Peripherals:
Mouse: Razer Deathadder 2013
Keyboard: Dell Default (Looking to upgrade for Christmas(Any suggestions?))
Headset: Razer Kracken Pro
The Problems:
-Loud
-Runs Hot after long gaming sessions(1h Prime95 = 82oC)
-Visually Boring and Unappealing
-Not Unique
-Cant Decide on Colour Scheme - Peripherals = Razer Lime Green/Components = Blood Red
The Plan:
1)Sand, Prime and Spray Mesh Strips, Shinobi Logo,Top Mesh and PCI slots in chosen colour.
2) Remove Front HDD Cage and dremel bottom of 5.25 cage
3) Add Custom Loop
-240mm rad in front
-dual bay res/pump combo in 5.25 bays
-CPU Block on CPU
-Coloured Tubing (dependent on scheme)
-Clear/UV Fluid
-POSSIBLE KIT - XSPC RAYSTORM 750 EX240
4) Led Lighting inside of case (dependent on scheme)
5) Cut New Perspex Window and Frost Decal onto it - Fit with fake bolts
This thread is a Work in Progress but I appreciate any suggestions massively on how I could get this build looking nice affordably.
Updates:-
19/11/13 -
Definitely going with Red colour scheme now.
Considering Dual Sleeving the PSU Cables in Red. Will be difficult with the non-modular PSU but would definitely be worth it. It Might be enough to just do the 24 pin, the 2 8 pins and the sata Harness and then i can hide the rest of the cables somewhere.
I've also come across about £50 more money now, Where do you think it would be best spent?
20/11/13 -
Spoke to my "technical adviser" in real life and talked through the practicalities of the mods.
Very good news, tomorrow I spray the components and cut the window. Then for free I can get the acrylic window laser etched with the MSI Gaming Dragon symbol on the side. I am going to mock up some photoshop things to see how it looks, apparently I could also get the dragon in red but I'm not sure how that would work. I will have a look tomorrow and post some pictures.
A quick mock-up of what I hope to achieve visually and what it will look like with the res(right):
27/11/2013 -
Didn't manage to get too much done this week. I remade the side-panel with a solid clear window and need to do maybe one more coat of red on the mesh. I have decided on the Red CM Storm Quickfire TK for my desk as this will actually give me decent mouse room and if I disable the LEDs on my mouse wont look too mistmatched. Next I have to decide on actual improvements inside the case. I will probably wait till after Christmas for most of this as I will actually have a considerable amount more money then but at Christmas I atleast hope to pick up a couple packs of SP120s and some nice red LEDS. I'm thinking if you guys are against the idea of a custom loop that I just get a h100i - I will have a virtually unlimited amount of clearance for rads.
The panel with WIP window:
01/12/2013 -
All of the mesh and everything is finished now and on the case, it's looking great. Today I tried out a red switch and realised I dont actually like them at all. This leaves me with a dilemma - I still like the Quickfire TK but I can go with Blues that will look out of place with my red system or I can go with the Red one which I'm sure I could get used to but would look amazing. Bearing in mind my mouse and headset are already green I'm sure it wont look too out of place. Any help would be appreciated.
15/12/2013 -
It's been two weeks since this has been finished and all I've done since is some sort of attempt at cable management, the PC is a mess round back but on the side I see it looks clear enough besides the one GPU cable that I have no choice but to have really visible. Sorry for my phone camera quality and the lack of light in the room but I've made do with what I've got to get you guys some pictures of the entire build to date.
First up a picture of the full rig in place:
Yes the walls and surrounding are ugly and I need a new monitor but this is what I have for now.
Next a couple of the peripherals:
I am getting a Blue Quickfire TK to go with this for Christmas and so I will actually have some mouse room for once.
The case from the outside(Excuse the print server on top):
The colour doesn't come out very well in this pictures but it is a very nice vibrant red with a subtle gloss finish. I did no surface prep on any of the painted pieces but they've come out great. I am also really happy with hte clear window although there was no chance I could get a nice picture of that without ugly reflections seeming as though most of the light was coming from a white screen on my monitor.
Lets pop the side off:
I'm not actually using any of the front hard drive cage bays so techincally I can drill that out and make room for a 240mm rad, I'l discuss why I'm not going to do that later.
A couple pics of inside:
And my crude attempts at cable management:
So that is my rig as it is right now but I have more plans. Whilst here I have secured a nice mechanical keyboard and some steam moneys I have managed to confuse my mum with 3 lists one after another. The first asks for a 7850(For litecoin mining) and some other things, the second asks for a define R4(As a replacement for my zalman z11 so i could silently mine) aswell as a 128GB SSD and the third asks for a white Corsair C70 (What i really want more than anything right now) Unfortunatly she has hinted that the last list was a little too late which suggests I am probably going to get one of the first two. Since I have no interest in litecoin mining seriously any more they will be kinda wasted although I know Ebuyer do operate a system where you can return any chrismas purchase before the end of january for a full refund which I may be able to arrange with her.
My new plan is simple. To save me money I will get a portable case such as the C70(Which i will attach some kind of appropriatly themed carrying strap to, and put all of my best components for both houses in there. I will ensure that I still have a basically functioning system at both houses but I will have the best gaming rig able to be moved at will. That way I can watercool that and put all of my money into one rig instead of splitting it across two. I will have to buy some new components to replace the ones in the Shinobi as shown here but the externals will remain the same. I think after the case I will buy another GTX 760 and put them in SLI while watercooling them using a strange passive/waterblock solution I have come up with.
That's all for today and will probably be it until Christmas is done. Any comments/suggestions are fully welcome and appreciated but most of it will depend on what I get for Christmas.
Thanks for reading, Folks.
  #2
Old 18-11-13, 10:57 PM
giannakos23 giannakos23 is offline
Member
nice idea !!
for peripherals though you can buy corsair keyboard and mouse...the k70 with red backlight...now you will need to change the mouse as well...the raptor m40 is really cheap and has red leds on it !!
waiting for an update
  #3
Old 19-11-13, 08:59 PM
jarthur36's Avatar
Newbie
Originally Posted by giannakos23 View Post
nice idea !!
I think I may well keep my mouse just disable the LEDs. New keyboard for Christmas have seen the k70 before and it looks quite nice. Headset I will have to wait for a while but i dont really mind, I can't see it when it's on my head anyway.
  #4
Old 19-11-13, 09:29 PM
Member
nice you won't regret it the k70 is a very good choice and it has a very elegant design !!
  #5
Old 20-11-13, 07:49 PM
jarthur36's Avatar
Newbie
20/11/13 -
  #6
Old 21-11-13, 01:29 AM
enRodjavel's Avatar
enRodjavel enRodjavel is offline
Newbie
Send a message via Skype™ to enRodjavel
looking good =D, even for being yet a Red and black build haha
__________________
i7 4790K, BeQuiet! SR2, Asrock z97e-itx/ac, XMS3 8GB,
GTX 670 2GB, Raid-0 3xKingston ssdNOW300V 120GB,
Bitfenix Prodigy, OCZ ZT 750W
Twittwit@enRodjavel
  #7
Old 21-11-13, 06:21 AM
SeekaX SeekaX is online now
OC3D Elite
you got 200 quid and want a custom loop? not worth it imo
go ahead with the rest though.
for the keyboard, the k70 is nice, but if you want a smaller one i'd take a look at the cm storm quickfire tk.
__________________
i5 4670k // MSi MPOWER // 4x4GB Corsair Vengeance Pro 2133MHz
Palit GTX 770 4GB Jetstream // Corsair RM750 // Zalman Z9+
Corsair Force 3 60GB // WD Green 1.5TB // Seagate Barracuda 2TB
Leopold Tenkeyless MX Brown // Zowie FK1 // Steelseries QCK+
Beyerdynamics DT 990 // FiiO E10 // Asus VG248QE // Asus VE228
  #8
Old 21-11-13, 06:49 AM
jarthur36's Avatar
Newbie
As I said, I have £50 more now. The loop would only be for the CPU but i like clear/translucent coloured tubes and the fact that I then have the option of expand it later. I can get multiple kits in the range of £100-200 including the extremely cheap XSPC Raystorm 750 EX240.
Thanks for your suggestion, I have disabled the LEDs on my mouse and that keyboard looks really good, especially seeming as I have extremely limited space on my desk. And its very cheap with Blues which is what I would have gone for.
  #9
Old 21-11-13, 06:52 AM
jarthur36's Avatar
Newbie
haha, I would be more adventurous if i had more money. I way considering carefully painting the heatsinks on the motherboard and the shroud on my graphics cad and making the whole thing green and black but decided I would probably break everything. It would have gone with my peripherals A bit better But Im happy with my current choice. I'm going to see if i can think up something super special to do to it.
  #10
Old 21-11-13, 06:53 AM
OC3D Elite
tbh those cheap kits won't perform any better than an h100i and i doubt that that pump could handle two rads + 2 blocks. if you don't have much to spend it might make more sense to spend the money on parts that offer more value for money, a waterloop really is a luxury that doesn't pay off.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
