Thread Tools Display Modes
  #1
Old 18-11-13, 01:43 PM
dladdin's Avatar
dladdin dladdin is offline
Member
new motherboard help
hey
I am currently looking for a new motherboard but finding hard to find ones...
I have a 4100fx cpu so that will be swapped into the new motherboard until i can get a better cpu.
I also would like to be able to crossfire so the board will need that too.
my current colour is blue so need a board that is black or blur no funny colours.
If any one can help would be a big help
Looking to spend about 70-100 pound !!!! thanks
DLADDIN
  #2
Old 18-11-13, 02:54 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Asus M5A99X EVO R2.0?
Or the Asus M5A97 EVO R2.0 if you're looking for something cheaper.
What CPU are you planning to upgrade to? Cause if it's not the 8320 or better it's going to be pretty pointless. You'll also need an aftermarket cooler with that and if you get the 990x board, you'll have the freedom to overclock.
Iirc, that board also supports 16x/16x CrossfireX which might be benificial on a platform that doesn't support PCI-E 3 yet. What GPU do you have?
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #3
Old 18-11-13, 03:04 PM
theDTP theDTP is offline
OC3D Crew
As stated above, the ASUS M5A99X EVO R2.0 is a good M/B and it is just in your price range at £97 on ebuyer and £99 on Overclockers
__________________
Intel i5 4670K | ASUS STRIX 980 Ti | 16GB Corsair Vengeance Pro | Gigabyte Z87X-UD4H |
OCZ ZT 750W | Samsung 840 EVO 500GB | CM Storm Trooper | H100i
| WD My Book 2TB
My Rig Gallery | Firestrike (#1 7950 x-fire, 4670k)
  #4
Old 18-11-13, 03:19 PM
dladdin's Avatar
Member
hey i have a 7770 2gb from asus and i already have a h80 watercooler really dont know what cpu i will be getting yet
  #5
Old 18-11-13, 03:21 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
for this. Its a good 'board and cheap. Only issue is it needs good airflow as the heat sinks are mostly under the radiator for any AIO cooler that has the radiator on the rear fan bit.
__________________
Rig: i7 4770k@4GHZ|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904|240gb+512gb Samsung evo 840| ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #6
Old 18-11-13, 03:22 PM
Feronix's Avatar
OC3D Elite
There's not much point in putting a 7770 in CrossfireX tbh. You'll be better off selling this card and buy one, higher end card.
Definitely do get an 8320. It doesn't cost that much (even for someone on a budget) and if you get anything below this chip, you might just as well not upgrade your CPU at all.
__________________
~Rick
  #7
Old 18-11-13, 03:25 PM
barnsley's Avatar
born in a.....
6350 and above for a CPU upgrade if you want to go AMD again otherwise its not really worth it.
__________________
  #8
Old 18-11-13, 03:27 PM
Feronix's Avatar
OC3D Elite
But then again the price difference between the 6350 and 8320 is only about 15 quid. I do agree with you, but for that price he might just as well go 'all out'. Specially with a board like this.
__________________
~Rick
Tags
am3+, amd fx, crossfire, new motherboard
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
