Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #1
Old 10-11-13, 11:57 AM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
memory problem
ok so i got 16gb (4x4gb) of corsiar's vengeance pro, which has a tested speed of 1600mhz. my problem is i my rig wont run it at 1600mhz, it says that my bios settings are wrong every time.i know my bios setting are not wrong, an as far as i am aware of its a problem with amd's memory controller, when all 4 memory slots are filled it likes to lick its elbow .anyway i was wondering is there anyway i getting better timings and a bit more from this memory, while its running at 1333mhz all thoughts on this welcome.
thanks guys
  #2
Old 25-11-13, 12:23 AM
dev_tomato dev_tomato is offline
Newbie
You won't see any real-world noticeable performance difference by going from 1333 to 1600. So I wouldn't worry about it.
  #3
Old 25-11-13, 12:26 AM
Tripp's Avatar
too many shrooms
yeah i know i am not too bothered, just annoying thats all
  #4
Old 25-11-13, 12:54 AM
theDTP theDTP is offline
OC3D Crew
I always say "should have, would have, could have" meaning you can't change the past, but... You "should have" got 2 x 8GB if you have an AMD chip.
Return it if it is possible and get 2 sticks?
__________________
Intel i5 4670K | ASUS STRIX 980 Ti | 16GB Corsair Vengeance Pro | Gigabyte Z87X-UD4H |
OCZ ZT 750W | Samsung 840 EVO 500GB | CM Storm Trooper | H100i
| WD My Book 2TB
My Rig Gallery | Firestrike (#1 7950 x-fire, 4670k)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
