Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Serious Discussion
Thread Tools Display Modes
  #1
Old 23-09-13, 04:40 PM
Remmy's Avatar
Remmy Remmy is offline
OC3D Elite
EL Wire Questions
Hi all, I've got some EL wire for a little window mod I'm doing. I'm going to run it underneath the U-channel around the edge of my window so it glows blue.
Firstly, does anyone know of any brand of good CLEAR/TRANSLUCENT U-channel, or where I can get some decent stuff? I bought some online recently and it was no where near flexible enough for my window. There is tons of black U-channel out there, but finding clear stuff is proving hard.
Now, onto the EL wire. I've never used it before so I just wanted to know whether I can change the connections around on it.
Here is the kit I bought
As you can see it has a 12v car cigarette lighter adapter, I assume I can simply snip this off, and wire it via a molex?
Preferably though, I would like to get rid of the little AC/DC converter box. So, would I be able to cut the converter off, and instead connect the EL wire to a 2pin connector, and stick it into my cathode converter?
__________________
  #2
Old 23-09-13, 06:03 PM
Goldskis45's Avatar
Goldskis45 Goldskis45 is offline
OC3D Crew
Send a message via MSN to Goldskis45
Yep, the plug can be snipped off and a Molex added.
Quickest way to find out would be to call the manufacturer and find out what the wire is running at.
__________________
(Backup Workstation)
CPU: i7-3770K MB: ASUS P8Z77-V RAM: Corsair 16GB
SSD: OCZ Vertex IV 250GB GPU: Quadro 2000 Case: Antec SONATA IV w/620W PSU
Tags
cathode converter, el wire, molex, u-channel, window mod
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
