Go Back   OC3D Forums > [OC3D] General Forums > OC3D Freebies
Thread Tools Display Modes
  #111
Old 03-09-13, 08:53 AM
tinytomlogan's Avatar
The Guvnor
Its also worth noting the people moaning its too hard are just lazy. That means those who put the effort in are in with a MUCH better chance of winning.
Out of nearly 1000 entries only 3 people actually read the T&C's and have submitted the correct page URL.
5 people have found the image but submitted the image url and sadly thats incorrect so will not be entered
n0000b filter working perfectly
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #112
Old 03-09-13, 09:00 AM
BradKing BradKing is offline
Newbie
3 out of 1000, sweet, will try during lunch break and at home, gl all
__________________
C2D E6600 @ 3.0 GHz, Scythe Mine, 4Gb RAM, MSI HD4890 OC @ 1680x1050
Crucial M4 128 SSD, 1TB Samsung Spinpoint II
  #113
Old 03-09-13, 09:10 AM
litchu litchu is offline
Member
It would be faster to get a job and work enough to pay for a 780 then go here and find the image. But you cant get rid of me that fast!
  #114
Old 03-09-13, 09:13 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
@ the adblock question...
Do us a freaking favour and turn adblock OFF for oc3d anyway.. thanks.. it helps A LOT.
__________________
Asus x79 Deluxe | Intel 3930k | 32GB Corsair Vengeance 1866Mhz DDR3 | 2 x 3GB Gigabyte Windforce 780GTX - SLi | Xonar Essence STX | 2 x 256GB Samsung 840 Pros | 2TB Samsung F4 | Corsair RM1000i | Caselabs SM8 - White | 2 x Alphacool 360x60 | Bitspower 400mm Res Top | Dual Laing D5 Pumps | Bitspower C47 Fittings | XSPC Raystorm | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #115
Old 03-09-13, 09:25 AM
JoshM689 JoshM689 is offline
Newbie
When will you give us hints! o.o we'll be here days. .. :'(
  #116
Old 03-09-13, 09:31 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
It's only been up a few hours, stop asking for hints so soon cuz you're not getting them :P.
Get on with searching chaps.
__________________
  #117
Old 03-09-13, 09:33 AM
The Guvnor
Someone found within 90 mins of the competition opening.
Even I dont earn £550 in 90 minutes!
__________________
  #118
SieB's Avatar
SieB SieB is offline
OC3D Elite
This isn't too bad if you are a older member.
It's good seeing some old threads and posts that I made, as well seeing old faces that aren't around any more.
Still boring, but interesting at the same time.
__________________
NZXT Switch 810 - i5 2500K - Gigabyte Z68 UD3H - 8GB 1600mhz Mushkin Blackline - Zotac 970 GE - Crucial MX100 256GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair HX850 - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #119
Old 03-09-13, 09:46 AM
Koiworks's Avatar
Koiworks Koiworks is offline
Newbie
Still cant believe the amount of people complaining about this!!
It's a free giveaway for an item that's worth quite a bit and all you have to do is browse a bit and sell your soul to the OC3D forum (yes, you do need to sell your soul when registering. It's all in the small print.)
And btw I'm here since 7am and still have not found it!
  #120
Old 03-09-13, 10:09 AM
The Guvnor
There are now 2 hints easily visable.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
