Originally Posted by VengeanceUK
is this radically different from the normal arc midi to warrant and upgrade for upgrading to w/c or is it simply exactly the same as the "v1" just with a window and the slightest of tweaks?
not radical.. front fascia difference, same chassis mount for roof. actual rad
attachment points for the front. clicky front grill for easier cleaning.
worth the spend? if you are not a fab/modder, yes. if you are handy with a
dremel, knibbler and file.. stay V1. ive got two of these V1 cases and was
almost ready to spend V2 money, but for looks, the front bezel is kinda
attractive with minimal logo placement. id like to sweat FD for a new bezel.
LOL
__________________
2700k|ASUS MIVE-Z|MSI GTX 780|Corsair Platinum 16GB 2133|CaseLabs SM8|Custom Loop
2500k|ASUS MIVG-Z|EVGA 660ti 3GB/SLI|Corsair Platinum 8GB 1866|FD Mini|Corsair H100
FX-8350|ASUS CVF-Z|Radeon HD7970|G Skill X 16GB 2133|FD Midi|Corsair H100
