Go Back   Overclock3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #11
Old 24-01-13, 05:53 AM
grassman's Avatar
grassman grassman is offline
Advanced Member
Send a message via MSN to grassman
Originally Posted by jamesriley94 View Post
Thanks!
I know - I kind of miss it actually. It was just so well built - and just makes the Switch feel cheap......well....actually, the fact that the Switch arrived to me with bits of plastic snapped off makes it feel cheap.
And you should do! It'd be nice to see what someone could do with it. I did consider trying to get a thin 360 in the roof then a thick 240 in the bottom. Still - as much as I loved it, I fancied a change.
On my end just that roof feels incredibly flimsy especially those push in lock thingys other then that its perfect! If you are on AIR you should have gone with the phantom personally I prefer the original looks.
__________________
Intel i7 3770k@0.85v | Asus Maximus IV Extreme-Z | 8GB Corsair Dominator GT 2133 | Sapphire HD 7970 OC |
Corsair H100i | 128GB OCZ Vector | Corsair GS 800| NZXT Switch 810 Black|
  #12
Old 24-01-13, 08:35 AM
jamesriley94 jamesriley94 is online now
OC3D Elite
Yeah, it is mainly the roof that I feel is cheap. It's one of the push fittings on the roof that snapped off, making the whole panel very shakey. There are push fittings all over the case however, which are probably less likely to break, but being push fittings, they'll only last a certain amount of time anyway.
Also the window panel isn't secured on as well as I'd have hoped.
Other than that though, I love the case.
And yeah, completely agree about the air, but hopefully by later today, I won't be
__________________
-----ASUS P8Z77-V Deluxe ---------- i7 3770k @ 4.6ghz-----
-----Custom Loop - Mushkin Blackline Frostbyte 1600mhz-----
-----GTX 670 - AX850-----
---Xonar Essence STX---
-----M60 - K90-----
  #13
Old 24-01-13, 11:36 AM
SuB SuB is offline
The Webmaster
if i can get it out, i might have a spare clip you can have if you're interested? (i got a replacement top panel due to a thumbprint in the black silk)
__________________
Asus x79 Deluxe | Intel 3930k | 32GB Corsair Vengeance 1866Mhz DDR3 | 2 x 3GB EVGA 580GTX FTW Hydro Copper 2 - SLI | Xonar Essence STX | 2 x 256GB Samsung 840 Pros | 2TB Samsung F4 | CM 1300W Silent Pro Hybrid | NZXT Switch 810 - White | Phobya G-Changer 420, XSPC 280 | RP-452X2 Rev 2.0 | Monsoon 7/16 Fittings | XSPC Raystorm | Roccat Kone | QPad MK85 Pro w/ Cherry Red MX | AKG K702 Reference Headphones | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5
Notice: Don't feed the trolls!
  #14
Old 24-01-13, 11:55 AM
OC3D Elite
Thanks for the offer - but from that, I think we're talking about different things.
The plastic clip bit on the left is non-existant (and you can see from the markings it's been snapped off.
I've contacted NZXT so will hopefully get a replacement, but as that's part of the panel itself, the entire vent panel would need replacing.
Thanks again for the offer
__________________
-----M60 - K90-----
  #15
Old 24-01-13, 04:27 PM
grassman's Avatar
Advanced Member
Same happened to me except I found that plastic part lodged into the push in tried pulling it out but its lodged in there goood and don't want to cause more damage.
__________________
  #16
Old 24-01-13, 05:27 PM
OC3D Elite
Yeah, it's not the best construction is it.
Currently leak testing...hopefully be have it running tonight.
__________________
-----M60 - K90-----
  #17
Old 24-01-13, 08:25 PM
OC3D Elite
Been a long day, but finally finished:
Few issues filling it - and the tubing was a nightmare to get on.
__________________
-----M60 - K90-----
  #18
Old 24-01-13, 08:28 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
That's pretty freaking awesome James, a rig to be proud of.
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Crucial M4 128GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #19
Old 24-01-13, 08:35 PM
tinytomlogan's Avatar
tinytomlogan tinytomlogan is online now
The Guvnor
Looks epic mate Kudos.
Nice to see the forums really helping someone
__________________
my baby is blue..... atm
  #20
Old 24-01-13, 08:46 PM
FredEx's Avatar
FredEx FredEx is online now
OC3D Crew
Looking good, guy! I really like that vid card set-up.
__________________
Thank you Tom Logan, Corsair and Gigabyte!
OC3D Overclockers Club Member
#022
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
