Go Back   Overclock3D Forums > [OC3D] Hardware & Software > Software Section > OS & Apps
Thread Tools Display Modes
  #21
Old 14-01-13, 07:16 PM
Dover8 Dover8 is offline
Newbie
Originally Posted by josh weston View Post
i recommend lying to your wife, and getting an ssd anyway
yes!!
  #22
Old 06-03-13, 02:00 AM
Glory Glory is offline
Newbie
Originally Posted by Yeren View Post
OK so this is the screen where your supposed to pick a place to install windows and thisis what i have
That is my external HDD which you can not install upon, you see a format button under there and that is the format button he pressed, and clicked Ok to the follow screen, does it mean i need a new HDD? as its a perfect excuse to go get my a SSD, but at the same time i would just love to be ableto use use my own computer instead of my wife's which isn't that great
Okay, what you need to dois make that hard drive the primary drive I used a program called Easeus to do it. Once you do that windows will recognize it as a HDD that can carry an OS and try to boot from that. If it keeps failing it may be your copy of windows as was with me when this happened.... got a new copy tossed the old copy and it booted right up (mine was on a new build)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
