Thread Tools Display Modes
  #11
Old 31-12-12, 01:42 AM
SeekaX SeekaX is offline
OC3D Elite
lol. well if the post is 6 months old i have no idea what he intended to get for that money with the i5 included
__________________
i5 4670k // MSi MPOWER // 4x4GB Corsair Vengeance Pro 2133MHz
Zotac GTX1070 FE // Corsair RM750 // Zalman Z9+
Corsair Force 3 60GB // WD Green 1.5TB // Seagate Barracuda 2TB
Leopold Tenkeyless MX Brown // Zowie FK1 // Steelseries QCK+
Beyerdynamics DT 990 // FiiO E10 // Asus VG248QE // Asus VE228
  #12
Old 31-12-12, 02:10 AM
rumblejack101 rumblejack101 is offline
Newbie
Originally Posted by Josh Weston View Post
Drop the i5, get an i3, spend more money on the graphics card. This is for gaming, where the GPU horsepower is far more important.
I would agree. Most games are not going to be restricted by a lower end CPU as they are much more GPU dependent. As you are looking for something with a mid range high end graphics card the CPU will not be a bottleneck. Don't forget in my opinion a small boot SSD is a must have part nowadays. If you are not used to using them the difference in everyday use is night & day, & they are cheaper than ever. The rest of the parts look solid would change the GPU to a newer model tho.
__________________
Asus p8z68-v Gen3
Intel 2600k @4.6mhz
Zalman cooler
2x EVGA GTX680's
16gb Crucial bilistix tracer
Corsair gs800
Corsair 120gb force3 ssd
Haf932 Advanced (with mods)
  #13
Old 31-12-12, 07:19 AM
CPMFW's Avatar
CPMFW CPMFW is offline
OC3D Elite
Aw, man. I only ever really look at the post above mine
me too
__________________
  #14
Old 04-01-13, 03:46 PM
Bang's Avatar
Bang Bang is offline
Advanced Member
Do you have an exsisting case that you can use for a short time, to ease the burden of budget? Mayhap the i3 3220 is in order?
__________________
CPU: Intel Core i5 3570k
Mobo: MSI Z77A-GD65
RAM: 8GB G.Skill Ares @2133Mhz
GPU: Gigabyte GTX550 Ti GV-N550D5-1GI
Audio: Onboard with Digital out to Logitec Z5500 5.1 THX decoder.
PSU: Thermaltake Litepower 700w
Case: Thermaltake Dokker
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
