Go Back   Overclock3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #1
Old 29-04-12, 10:43 PM
Jadarite's Avatar
Jadarite Jadarite is offline
OC3D Crew
Send a message via MSN to Jadarite
Hi all i was just reading the asus motherboard P8Z77-V Deluxe user guide and in there it says that this motherboard does not support DIMMs made up of 512Mb (64M chips or less (Memory chip capacity counts in Megabit, 8 Megabit/Mb = 1 Megabyte/M.
So my Question is which ram would you buy?
All help welcome
__________________
"The answer to life the universe and everything is 42 "
Power Supply Calculator Guide (you might have to F5 this)
  #2
Old 29-04-12, 11:31 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
best look on the ram compatability list on Asus's site. I watched a video a lil bit ago where they claim they now are using future spec from intel for an upcoming change in chip design that allows more bandwidth. This vid said when they did their testing on the Z77 boards they used 2800 speed for all testing as a norm without any difficulties.
http://dlcdnet.asus.com/pub/ASUS/mb/...E-QVL-0405.pdf
__________________
Switch Blade
Gigabyte GA-Z68X-UD4
Intel Core I7 2600K
2x Kingston Hyper X 3K 240Gb SSD's in Raid0
WD Black 1TB Storage
HIS 7970's in Crossfire
Custom Cooled 420mm & 280mm rads
NZXT Switch 810 Corsair AX850
  #3
Old 29-04-12, 11:46 PM
Jadarite's Avatar
OC3D Crew
http://dlcdnet.asus....XE-QVL-0405.pdf
Thank you sin, I was looking at these what do you think http://www.crucial.c...1A62B7DA5CA7304 and these http://www.shop.bt.com/products/cors...m_content=RR00
__________________
  #4
Old 30-04-12, 12:42 AM
S_I_N's Avatar
OC3D Elite
the vengance over the balistics mainly due to cost difference the 2x8gb kit is twice the 4x4gb kit. But both are great ram. But question knowing that the board you picked will do up to 2800 speed why get 1600???
__________________
Switch Blade
Intel Core I7 2600K
  #5
Old 30-04-12, 07:08 AM
Josh Weston's Avatar
Josh Weston Josh Weston is online now
The Apprentice
Send a message via MSN to Josh Weston
You begin to pay a premium when you go above 1600, and, unless you're really into your rendering etc, I doubt you'll see much difference from 1600 RAM. A decent set of 1600 RAM can usually be overclocked a little higher, anyway.
__________________
  #6
Old 30-04-12, 07:21 AM
I Hunta x's Avatar
I Hunta x I Hunta x is offline
OC3D Elite
My first question is do you even need 16gb of RAM?
If something other than "100% yes because ....." then something like this would be a better choice imo.
http://www.aria.co.u...productId=44336
__________________
i7 970 - NH-D14 | Gigabyte x58a-oc | Corsair AX850 | CM Cosmos S
6Gb G.Skill Trident - 1600Mhz c7 | SLI GTX 580
Xspc Rasa | Phobya G-Changer 240 | Phobya dc12-400 | 7x Orange Xigmatek XLF 120mm
| 2x EK 580 blocks
-Needed-
360 G-Changer |
200mmish Tube res | Orange coolant | Alphacool Copper Barbs, Spring clamps + CPU Screw kit
  #7
Old 30-04-12, 12:15 PM
Jadarite's Avatar
OC3D Crew
As i'm only going to be web browsing, gaming (bf3), music production i.e sampling, editing, and if what the user guide says is true then i'll only be looking to get 1024 x 64 ram and really don't want to spend more than £150 on ram
Hiya is that ram 1024 x 64 or is it 512 x 64
__________________
  #8
Old 30-04-12, 07:50 PM
Jadarite's Avatar
OC3D Crew
Your absolutely correct, especially when your looking for 1024Mb X 64 ram
__________________
  #9
Old 30-04-12, 08:04 PM
SmoulderingCircuits's Avatar
SmoulderingCircuits SmoulderingCircuits is offline
OC3D Elite
Yes, what are you actually using the rig in question for? Unless you're gaming at huge resolutions or doing extreme rendering/ editing work then there is no reason to buy anything other than value RAM. I'd vouch for 2GB 1333Mhz CL9 Crucial Rendition at £7 a stick.
In the event someone is upset about spending a fortune on 8 sticks of 4GB 2133Mhz after reading the above, let me say that I have personally tested RAM frequency and latency and a whole multiplier bump or CAS increment decrease (eg. CL9 to CL8) will only earn you an extra 0.02pts under Cinebench R11.5 x64. tested on a 1090T and Formula IV with 2x 4GB of 1333Mhz CL9 Corsair.
__________________
Subroutine
Lubuntu 12.10 | 2880x1024 | AMD E-350
Full CV & more...
  #10
Old 01-05-12, 12:39 PM
magicc8ball magicc8ball is offline
Member
Hell I bought some mushkin black line ridgebacks 2000mhz 8gig kit for 79.99 usd. It is CAS 9 so it will be plenty fast for what I do.
As others have stated when you get up to the 2133 you will be spending at least a 100 for a decent 8 gig kit and if you really want some nice ram be prepared to spend in upwards of 140 on up usd.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
