Go Back   Overclock3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 31-03-12, 11:44 AM
Watsyerproblem Watsyerproblem is offline
Member
i currently own a gtx 460 768mb card and i am looking for a bit more gpu horsepower. my question is should i go for sli and will i have any problems due to the low frame buffer, i have read ttl's and Mr strawberry's reviews on sli and it seems to not have harmed their results.
my card is overclocked to 850mhz on the core and 2045mhz on the memory.
  #2
Old 31-03-12, 12:15 PM
SnW's Avatar
SnW SnW is offline
OC3D Elite
Depends a little on what games as not every game uses SLI...
but hey if you can, I say: do it...........
__________________
sig update v1.1.
The Iron is the best antidepressant I have ever found. There is no better way to fight weakness than with strength. Once the mind and body have been awakened to their true potential, it’s impossible to turn back.
  #3
Old 31-03-12, 02:43 PM
I Hunta x's Avatar
I Hunta x I Hunta x is offline
OC3D Elite
If your main games include bf3 or skyrim selling your 460 and putting the money towards a card like a 7850/570 will help more than a 2nd card just because of the extra vram tbh.
__________________
i7 970 - NH-D14 | Gigabyte x58a-oc | Corsair AX850 | CM Cosmos S
6Gb G.Skill Trident - 1600Mhz c7 | SLI GTX 580
Xspc Rasa | Phobya G-Changer 240 | Phobya dc12-400 | 7x Orange Xigmatek XLF 120mm
| 2x EK 580 blocks
-Needed-
360 G-Changer |
200mmish Tube res | Orange coolant | Alphacool Copper Barbs, Spring clamps + CPU Screw kit
  #4
Old 31-03-12, 02:55 PM
Member
i am well aware that not all games support sli or crossfire, my main concern is a performance bottleneck in games like battlefield 3 or crysis 2 due to the low video ram. I'm playing in 1080p.
I'm able to buy an identical card for quite cheap, and i do not have the funds atm to get a £200 card even if I got a good price for my 460.
  #5
Old 31-03-12, 03:07 PM
I Hunta x's Avatar
OC3D Elite
On high preset at 1080p on bf3 i usualy sit around the 750-850mb vram mark so you would be better with a single higher end card with some more vram (like i said before a 7850/gtx 570 will be spot on and will be around £200)
__________________
| 2x EK 580 blocks
-Needed-
360 G-Changer |
  #6
Old 31-03-12, 03:14 PM
Member
as i said before i cannot afford either of those cards, i have a max of £80 and what i can get for the 460 (provided i can get a buyer)
  #7
Old 01-04-12, 12:11 AM
reeper250's Avatar
reeper250 reeper250 is offline
OC3D Crew
I was running two EVGA GTX 460 SC 1Gb cards in SLi, they are VERY good for the price you pay!
__________________
i7 3930k, Rampage IV Extreme, 7970, 16GB Ripjaws Z
Nuclear Fission
Nuclear Poison
Copperhead
  #8
Old 02-04-12, 02:14 AM
MaXiMiZe MaXiMiZe is offline
OC3D Crew
Due to your low budget I'd say yeah gtx 460 sli would be your best bet
  #9
Old 02-04-12, 02:50 AM
Firat's Avatar
Firat Firat is offline
OC3D Elite
i would always say invest in the more efficient and new products out there but the best improvement you will get in your budget = another 460
__________________
The brave may not live for long but the cautious never live at all.
If it takes you longer to do something than to think it up, then you need to plan again.
  #10
Old 06-04-12, 09:49 PM
Member
after some consideration i have decided to wait and buy a single more powerful card at a later date when it becomes financially feasible.
thanks to all who posted your help and insight was appreciated.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
