Go Back   Overclock3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 08-02-12, 11:24 AM
nothingspecial's Avatar
nothingspecial nothingspecial is offline
OC3D Crew
Got a G5 Mac Pro that is grinding along, and on observation it does have a PCI Express slot.
Question is, will any old card work in there, or (as I assume) will it need Mac specific drivers? If so, does anyone know of a card/vendor that might have them?
Very much uriniating in the wind with this one, as I've never really worked with Apple stuff before.
__________________
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature to help him gain world domination.
  #2
Old 08-02-12, 12:17 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
You need a MAC specific card and they are expensive. On the Apple store, a 5770 is like $250. I'm sure you can find cheaper at a reseller though. Also, make sure the card is compatible with your MAC.
__________________
i7 930 | GA-X58A-UD3R | GTX680 | 6GB DDR3 | Crucial C300 SSD
3DMark11 - P10045 | X3680
  #3
Old 08-02-12, 01:19 PM
FTLN FTLN is online now
OC3D Crew
Originally Posted by nothingspecial View Post
Got a G5 Mac Pro that is grinding along, and on observation it does have a PCI Express slot.Question is, will any old card work in there, or (as I assume) will it need Mac specific drivers? If so, does anyone know of a card/vendor that might have them?Very much uriniating in the wind with this one, as I've never really worked with Apple stuff before.
You just need a efi compatible bios for your gpu (be carefull mac bios's can be larger than the eprom on cards designe for windows) - Visit Netkas.org for more info... G5 Is old architecture so Driver mods may only be targeting x86 nowadays...
My GTX 560 from Msi with a few modded drivers runns much faster in an opencl enviroment in Lion than it does in windows...
Here is 560 booted into Lion 10.3.3
And in Win 7 X64
__________________
Our OS who art in CPU, UNIX be thy name. Thy programs run, thy syscalls done, In kernel as it is in user!
  #4
Old 08-02-12, 01:33 PM
equk's Avatar
equk equk is offline
OC3D Elite
As it's a G5:
it won't be based on EFI
the expansion slot will require a mac specific card as it makes use of extended firmware (bootup vga functions/registers)
it will not support lion** (the latest version it will support is leopard 10.5.8)
** a lot of new retail 5xxx + 6xxx cards work out of box on lion as the device id's exist in the new ati drivers
Apple official site: Power Mac G5 (Late 2005) and Mac Pro: Graphics card compatibility between models
Although the Power Mac G5 (Late 2005) and Mac Pro models both use PCI-E (PCI Express) based graphics cards, the cards are not necessarily interchangeable between models. Learn which cards work with each generation of computers.
Depends on what model you have etc
I think the best thing to do is get some advice from a mac store if there's one close or ping them an email as there are a few models.
__________________
  #5
Old 08-02-12, 03:34 PM
Rastalovich's Avatar
Rastalovich Rastalovich is offline
OC3D Elite
Annoying isn't it.
I've got a bunch of ppc G5s, some decent enough processing power to use 10.5.8, but the best gfxcard I got is a 6600.
Yes, Ouch!
Would be nice if even a PCI graphic card could go in there. You can't tell me with all the hackintoshing going on that by some mysterious linux related fete, someone couldn't mush something together.
Even if it's to keep the 6600 in there to boot, and opt to the *whatever* PCI card after. Not necessarily a new driver, just something to recognize it and use and old driver - just using the acceleration of the newer generation.
Bah!
1 tip for ya'll though, and it took me a while to figure out why they start off great with leopard, then trudge down, - turn off pdf indexing in Spotlight. Infact turn a load of things off in Spotlight. It attempts to run whilst you're doing stuff, indexing for search reasons, and makes your fans go crazy(er).
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
