Go Back   Overclock3D Forums > [OC3D] General Forums > Overclock3D Reviews
Thread Tools Display Modes
  #1
Old 30-08-10, 09:32 AM
tinytomlogan's Avatar
The Guvnor
Following the enormous success of their Megahalems CPU cooler, we take a look at the Prolimatech MK-13 VGA cooler.
Continue Reading
__________________
my baby is blue..... atm
  #2
Old 30-08-10, 10:13 AM
AlienALX AlienALX is offline
member
Send a message via MSN to AlienALX
Originally Posted by VB View Post
As if to make matters even more enjoyable, when we moved the card amongst our various motherboards attempting to find one that it would fit into without fouling the chipset heatsink, the RAM sinks fell off. We were really gentle too.
Which just so happens to be the same issue attatched to nigh on every third party GPU cooler on the market today.
And that causes fast death of a GPU. For what they charge for these things you would think that they would get that sorted out. I mean, surely some one some where in testing said "Oi, my ram sinks bloody fell off !".
Thanks again for a wonderfully honest review Mr VB. I shall avoid like the plague.
  #3
Old 30-08-10, 10:32 AM
Ari-M. Ari-M. is offline
Newbie
Actually I have never had that issue with my Zalman stick on heat sinks. I am always sure to clean the chips with denatured first. The heat sinks on my gts250 have been in place through quite a few installs/system builds (gts250 is my test card) and less than gentle handling. Never had one fall off yet.
I have used the same Zalman stick on sinks on a variety of chips (sata controllers. etc etc etc) and have actually never had a single one fall off. I have probably used a few dozen of them over the course of the last year or so (building various systems and outfitting various cards/chips)
As long as you clean the surface you are sticking them to, they seem to work great.
I have certainly heard that others have bad luck with them though. Maybe it's the lack of prep. when putting them on? Or maybe I have just gotten lucky.
As for this VGA cooler in review....why would someone build a product that takes up 4 card slots? Was an intern somehow in charge of product design on this item? I just don't get it. They should have just designed the heatsink itself with an indentation in the middle...and then some clips to mount a fan.....same way as everyone else builds their coolers. Really an odd departure from a company that builds such well though out products.....
Seems like by the time you buy the product and then add 2 fans, you are far beyond the value of some of the cards this item is meant to cool, I mean could you imagine such a cooler on a card like a GTS250? You would have a $200 (US) plus GTS250.
For $20 more you could get a 460 or for about $60 more a pair of 5770's. Neither of which needs aftermarket cooling. *scratches head*
  #4
Old 30-08-10, 12:19 PM
silenthill silenthill is offline
Member
when you install a third party VGA cooler you void your warranty and the company that makes the cooler doesn't give you a warranty so if anything goes wrong you have nowhere to turn too, doesn't that seem stupid or money just grows on trees these days for some people.
__________________
CORE I7 920 @ 4.3 GHz - GTX 480 SLI OC TO 800,1600,4000 ----- CPU-Z
  #5
Old 30-08-10, 01:43 PM
Newbie
it makes sense if you have an older card, that you got super cheap. I personally did the upgrade to my gts250 because I couldn't stand the noise that the stock cooler put out....it basically ran 100% all the time, with no option to adjust fan speed (not even building a custom permission in RIVAtuner would allow fan control).....and I got the card for next to nothing. Same with the aftermarket cooler. I think I have less into the combo than the cheapest gts250 sells for on newegg.
So for system building and testing mobo/ram/cpu on builds it's a great solution....this way if I get a faulty PSU or mobo I dont' fry a valuable GPU while burning in other components. Also it's super quiet now and I don't have to hear it screaming on the test bench for a 48 hour burn-in
Would make much less sense if all the items were new, and you were paying MSRP. Then I have to agree with you, it's just silly.
  #6
Old 30-08-10, 01:57 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Just about every card I have owned since a GeForce 2 Ti has had an aftermarket cooler. (Blorb on the GF2, remember those? lol) Not only do you get better cooling, but you can also clock higher and at lower noise levels than a stock cooler. I still have stock cooling on my GTX470 only because it is actually a good solution.
Worrying about a warranty is silly IMO. If you break the card changing the cooler it's your fault, but if the card happens to die a few months down the road from no fault of your own, just slap the stock cooler back on.
Back in the 9800 pro days, the stock cooling was well past inadequate and caused the cards to die prematurely. Overclocking was out of the question with stock cooling. Attaching an AC silencer (or a 1U copper server heatsink) was the only option.
I usually buy a new cooler WITH the brand new card. I only use stock cooling to test the new card and make sure it's not DOA, then the better third party cooling goes on.
__________________
i7 930 | GA-X58A-UD3R | GTX680 | 6GB DDR3 | Crucial C300 SSD
3DMark11 - P10045 | X3680
  #7
Old 30-08-10, 02:39 PM
AMDFTW AMDFTW is offline
OC3D Elite
lol fail
  #8
Old 03-02-11, 05:36 PM
Navu Navu is offline
Newbie
It seems you have installed the L-shaped bracket i.e. the fans all wrong: there is a "huge" 2 cm gap between the fans and the outer surface of the MK-13 fins. This gap eliminates the airflow towards the cooler, having installed the L-shaped bracket the other way around and so the fans in direct touch to the cooler would have resulted to much better temps. I'm using the MK-13 to cool my XFX5870 using two rather weak 120mm fans (in "direct-touch mode") rotating at 650-700rpm, the result is I have never seen temps higher than 46 degrees for the GPU (that's 50 for memory and 52 for the VRMs using Thermalright VRM R4). At full throttle of about 1400rpm, CCC/Aida64 Extreme/GPU-Z indicate amazing 38-40 degrees!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
