Go Back   Overclock3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 25-03-10, 09:17 PM
lf751 lf751 is offline
Newbie
Changing card bios
Is it possible to change a HD2900 bios to a bios from a 3XXX bios?
  #2
Old 25-03-10, 10:41 PM
killablade killablade is offline
OC3D Elite
Why would you want to?
__________________
My *finished* build - KingPenguin
  #3
Old 26-03-10, 08:51 AM
Newbie
Because the bios in a HD2900 is *POO*, It's constantly crashing in DX10 games.
  #4
Old 26-03-10, 09:20 AM
tinytomlogan's Avatar
tinytomlogan tinytomlogan is online now
The Guvnor
Mind your language, Ive edited your post.
__________________
my baby is blue..... atm
  #5
Old 26-03-10, 09:45 AM
Newbie
Ok...um so would this bios be fine in a HD2900 pro..
http://www.techpowerup.com/vgabios/2...12.071220.html
  #6
Old 26-03-10, 09:51 AM
I Hunta x's Avatar
I Hunta x I Hunta x is offline
OC3D Elite
never reflashed a graphics card only mobo's, but i doubt it would work as there different different chips are they not?
__________________
i7 970 - NH-D14 | Gigabyte x58a-oc | Corsair AX850 | CM Cosmos S
6Gb G.Skill Trident - 1600Mhz c7 | SLI GTX 580
-Need to fit-
Xspc Rasa | Phobya G-Changer 240 + 360 | Phobya dc12-400 | 7x Orange Xigmatek XLF 120mm
| 2x EK 580 blocks | Alphacool Copper fittings
  #7
Old 26-03-10, 10:51 AM
Newbie
Well they are mostly the same internally, the 3850 has a few more features and a newer bios so it might fix my problems. I'm going to go ahead since I can just use the backup and restore.
  #8
Old 26-03-10, 11:35 AM
Newbie
Ok my HD2900 is now in a coma...um so how do I restore it because it's saying "adapter not detected" thing is apparently using a build in graphics chip (like I am now) disabled the other ports but I can't find a way to turn it off, do you think my other board with a build in ATI chipset I could enable multi-view which might then let me recover?
  #9
Old 26-03-10, 12:55 PM
OC3D Elite
you could always try
__________________
  #10
Old 26-03-10, 01:12 PM
Newbie
Well that didn't work, now it's back in the original pc but it now turns on (light flashes fans are still currently spinning) but no display. But it still said no adapter found message on Atiflash, could someone help me here?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
