Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 14-11-08, 11:10 AM
PV5150 PV5150 is offline
OC3D Elite
Kingston HyperX line gets new heat spreaders
Kingston redesigns heat-spreaders for enthusiast-class memory modules.
Details in the press release
__________________
Originally Posted by name='Jim'
"Jonathan 'Fatal1ty' Wendel may be 12-time world gaming champ, but how does he cope inside a 50c hot box sucking on a heavy load?":rocker::rocker:
  #2
Old 14-11-08, 11:30 AM
JN JN is offline
OC3D Elite
They look pretty slick tbh
  #3
Old 14-11-08, 11:48 AM
Kerotan Kerotan is offline
Advanced Member
They look well smart! Would look even better with a black/blue PCB imo
__________________
  #4
Old 14-11-08, 11:54 AM
Rastalovich's Avatar
Rastalovich Rastalovich is offline
OC3D Elite
Wc people aint gonna care too much about this, but even tho I like the looks of these sticks, the higher the profile, the lesser the options for cpu fan options.
It`s difficult enough having a high bridge cooler, the pwm cooler, then some ram profiles that are darn tall b4 u even put a fan on them. It can lead u to 3 sides of a cpu-tower cooler not being accessible.
Not necessarily the ram manufacturers fault 100%, but they are at the disadvantage of having dimm slots directly to the rear of the cpu area. So if u want to blow across ur cpu and out the rear - ur knackered.
Have seen an Intel i7 mobo where they`ve moved the dimm array to above the cpu and parallel to pci slots, which could be interesting - atleast in this fashion, the air cooling techiques can attempt to flow 1 way.
Probably great ram outside of the rant tho
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
