Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 29-07-08, 04:11 PM
Deshman Deshman is offline
Advanced Member
Unusual Laing DDC-1T Ultra Pump Noise
Like the title says, there's a strange noise coming from my pump. At first I thought it was a HDD problem as it sounds quite similar to the noise my Seagates make when you load; that quiet, low but quick, repeated, random arm-seeking noise.
After disconnecting all the HDDs in my PC I confusedly narrowed it down to the pump. Turn off the pump, the noise stops. The res is almost full (400/500ml) and after searching the loop I can't see any signs of an air bubble. According to my fan monitor the pump is running at between 4500-4600 RPM.
Am I being too over critical here or is something going seriously wrong?
__________________
Initial Watercooled Build Log: linky
  #2
Old 30-07-08, 01:08 AM
Marcus Marcus is offline
OC3D Crew
What top are you running on the pump, XSPC?
  #3
Old 30-07-08, 03:54 AM
Advanced Member
XSPC Delta apparently, yes. It was my first pump so I got it sent pre-built.
__________________
  #4
Old 30-07-08, 08:04 AM
OC3D Crew
I've heard of this problem a couple of times recently, see here:
http://www.watercoolinguk.co.uk/foru...hp?f=24&t=4240
  #5
Old 30-07-08, 04:17 PM
Advanced Member
Thanks that was a great help Released each corner screw by 1-1.5 turns and the noise has nearly entirely gone - to hear it you have to put your ear next to it and even then it's very feint.
Still can't help the feeling that I've left myself open to a leak though.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
