I have have these two and would like to know did anyone have to disable anything in the BIOS to overclock. I am getting seriously high temps around 85-90+oC without overclocking so i would like to know thnx. I am using H100i and have resitted the cooler a billion times and there is nothing wrong with pump or anything.
Yes I have a 4790k and VII Hero, and mine idles at around 28°c and under load hits 65°c thats at 4.4GHz, at 4.8GHz, it idles at 32°c and under load it hits around 95°c and that is about 1.35Volts.
So the information needed would be,
1. what speed is the CPU running at? eg 4.4GHz Turbo speed
2. What Voltage have you got for any overclock or just Turbo speed? (use CPU-z when you are getting the abnormal temps to get all the info needed)
3. Have you made any changes yourself in the bios or have you left it running at default settings?
4. Are you getting these abnormal temps while running anything in particular, is it random occurrence, all the time, or when something specific is done?
5. You say you have re-seated the CPU several times, have you damaged / bent any pins in the socket?
6. Is it just your CPU running hot, or is your Graphics Card, memory and or power supply also doing same?
I can't think of anything else to add to list of questions rattling around in my head at moment, but if you could answer some if not all of these, it will help narrow down things as to why and how things aren't right for you.
Need ALOT more information, what your volts and so on.
What mark a you going after and do you take it by step by step ?
Will also like some picture, so we better can help you
lol you had same thoughts as me, just beat me to it though
