Everyone is so smart but you are all thinking ahead of yourselves..
Everyone is SO quick to assume that the same fan would be better without actually using logic when taking a lot into consideration.
Fans made for static pressure only perform better when something is in front of them.... :mellow:
So the SP fan would be good to use for PUSHING the air into the Radiator.
The AF fan would be better at pulling.
Using the same fans in both push and pull would cause the pull fan to out perform the push fan no matter what fans you use because there is nothing blocking the airflow of the pull fan, it will obviously blow a higher cfm..
Also take into consideration that even an SP fan will be hindered by having a radiator in front of it.
So the real answer to this mystery can be found using a very common problem solver we like to call math.
You have to take a lot into consideration.
The higher CFM/SP fan will be better as the push fan because it will allow for better airflow
The airflow fan will be better for the pull fan because there will be nothing blocking its airflow and will be able to perform how it is meant to.
Whichever fan you use will have its CFM drop the higher density of the Radiator/Heatsink. Which means you want to use a higher RPM fan as the push and the LOWER RPM fan as PULL.
Some math must be done to figure out the curve.
Example:
Your SP fan is pushing 40cfm through your radiator at 1500 rpm. If the SP wasnt pushing through the radiator at 1500rpm and had nothing blocking its airflow, it would achieve a higher CFM (lets say 60cfm).
Take your AF fan and find out at what speed it will get the same CFM (40cfm) without blockage. Chances are the af fan will only have to run at about 1300 RPM to achieve 40 CFM. So that would mean a fan that runs at 1300rpm and pushes 40cfm without blockage should be your choice for pull.
An SP fan that pushes 40CFM at 1500 rpm can be your second choice.
So the Pull fan does NOT need to be optimized for pressure.
It does NOT make sense to use pressure fans as PULLERS.
It does not make sense to use the SAME fans for push/pull (unless you lower the RPM of the PULL) because the pushers performance will be hindered due to the radiator blocking it. which will turn your matching RPM/CFM Fans into unmatching fans..
You want to match your CFM of your unblocked pull fan to the CFM of your blocked PUSH fan.
Think before you write things people.. And don't be so quick to assume things without thinking them through. ^_^
Figure out your CFM Curve and match your CFM. Do not match your fans unless you can use a fan controller to turn the RPM of the pull fans down a bit to match. :mellow:
I will say it one more time in case anyone couldn't understand my rant.
The RPM of the fan doesn't matter. what matters is what CFM you get in what circumstance.
If you use the same fan at the same RPM you will not achieve the same CFM with both push and pull fans.
The PUSH will have the lower CFM.
This is bad.
It is much better to mix and match fans or lower the speed of your pull fan to match the CFM of your push.
You may be able to accomplish this using sound as a reference, but this will be hard for anyone who has little experience with fans. :lol:
Cheers EVERYONE! And I hope I made you all think about this a little differently.
