Scoob
Hi all,
Putting this in "New Build Advice" as it's the best fit I could find...
Basically, I need a half way decent wired multimedia keyboard with at least one built-in USB port. I had an older Dell keyboard with this feature - it just died - and it's so very very useful. I generally just plug a mouse into it - the keyboard is on a USB extension, and the mouse goes into the keyboard for tidyness.
Now, many of you will say "why not just go wireless?" well, I have, many times and wireless devices never work properly here. Go figure. Really, I've spent a lot on decent Microsoft and Logitech Wireless Keyboard and Mice and NONE of them have worked well. Ever. Wired on the other hand works, as you'd expect.
On my gaming PC I have a Logitech G110 keyboard - it has a single USB port, so would do the business. I paid £40 for it a while back, now I've seen them for as much as £70!
So, any recommendations & a link to somewhere (UK) with said item in stock? I've been trawling through listings for an hour and a half & no luck.
Cheers,
Scoob.
Cheers,
Scoob.
