clone38
New build log for my new case got the name from the rad that will be installed into it.
A very big thank you to Tom @ Chilled pc for the great work done on the case its spot on to what i was looking for.
Case--Lian li v2000
Powdercoated white
Inside done in satin black
Lower rad cuts to both panels
2 X 140mm fan cuts in the roof with custom grill
Window panel cut
Mesh for the rad and window cuts AC Ryan black hexx
Hardware
Cpu--i7 920 (Air cooled for now)
Motherboard-- Asus Rampage Extreme II
Memory--- Corsair PC3-12800C8 1600MHz (3x1GB) Triple Channel DDR3 (Corsair memory cooler fan blades painted white)
Videocard--EVGA 285 FTW
Psu---Be Quiet! Dark Power Pro 750watt
Hard drive---Western Digital VelociRaptor 150GB
DVD Writer Painted satin black
Case Extras
Lian Li EX-33 Painted satin black
Lamptron FAN-ATIC Baybus (Painted white to match case)
Lian Li stealth DVD drive
Lian Li mesh bay covers
Black Lian Li wheels
Bitspower X-Station 2 power extension block
Watercooling parts
Rad--Feser Xchanger Black Monsta Extreme Radiator 420/360
Fans--6 X Yate Loon 140mm
Fittings--10 X Bitspower 3/8in. Compression Fittings for 5/8in.(For cpu,gpu,n/b,s/b and mosfet blocks)
4 X Feser 3/8" ID - 5/8" OD Compression Fitting (Rad and res)
10 x Bitspower 45 rotorys
Hose--10 X (XSPC)3/8" ID - 5/8" OD White hose
Pump--Laing DDC1+ Ultra 18W (MCP355) with Laing DDC Top/w Reservoir (XSPC)
Laing DDC 4 Point Anti-Vibration Damping Kit
Cpu waterblock--Watercool HeatKiller CPU LGA1366 Rev. 3.0 LT
Mosfets-- 2X EK
Northbridge/southbridge--Koolance MB-ASR2E & DRAM Cooler for MB-ASR2E (Both tops painted satin black)
Now for a few piccys i will update when i can but work has me very busy at the moment.
Case--Lian li v2000
Powdercoated white
Window panel cut
Hardware
Case Extras
Watercooling parts
Mosfets-- 2X EK
