some pictures on my main computer.
the glowing thingy is a chromatic windmill fancontroller with 3 temp sensors but the d*** clock keeps changing time :banghead:
the 2 front leds have been removed, i sometimes sleep on the couch and they are quite bright.
the second and third image shows the 120mm sidefan i put in some time ago.
the white socket in the middle of the image goes to the sidefan and they disconnects fine when the side is removed.
in the lower right you se the 92mm fan used to create more airflow to the passive zalman heatsink on the chipset.
works quite well temp is up to 50c on the base of the heatsink.
in the second image you se my new shiny thermalright ultra90 heatsink
works well and is much quieter than the zalman 7000b alcu i used to have in there.
have the panaflo fan on a zalman fanmate to reduce noise and cools the cpu to 45c today with a roomtemp of 27-28c and like it alot.
if you havent seen it yet but i HATE cables, they are all over the place and never where i want them to be
